I don't know if you'll get 2 grand worth of improvement the way I see it. My guess would be a couple of tenths, best. If I recall you were already at 133-134 in the quarter. Should be solid 9.80's. Tough for me to think a roller in the 270's would do much better. Jam the biggest Howards solid in there and see what happens for around 300 bucks. Check for coil bind that Howards is .667 lift.
