I rolled the engine with clay on top of the piston. I thought the best way was by measuring 10* ATDC?
While that may not be the best way to tell it does tell you how tight it is at the tightest point. But since you don't know exactly where that point is it makes it hard to use that data to compare to another camshaft.
