1969RR how do you like that Holley Sniper and fuel tank set up in your Challenger? Where are you running the vent line to?
Hello Plum72, I really like the way the system went in. Tank was easy bolt-in. Used 6AN feed and return to the tank. For the vent, I ran the hose and alumn fuel line up thru the trunk fill tube grommet. I just drilled a hole to fit the alumn line. Then ran the alumn line up next to the fill tube and attached the roll-over valve right next to the top of the fill tube. Easy to do. You're supposed to have the roll-over valve as high in the system as possible. Let me know if I can help you in any way. Take care, Jeff
