Close inspection of the shafts and axle ends revealed marks that I believe show contact with each other. Good catch, I really appreciate the heads up. I will definitely shorten them.
The thrust block moves about 3/8", so half that is 3/16", that would be the minimum clearance, I would do 1/4". As long as you have full spline engagement you can do more.
