Yeah, I fully expect that there is no way to get them completely quiet. I just thought I would try to reduce the noise some and at the same time experiment with the set-up to learn on a set of gears that I really can't hurt.
I'll blow it apart today and see what I can do.
Now, is it realistic to expect to be able to remove the pinion bearing without ruining it? And tips, tricks, or suggestions are welcome.
