Somewhat from out of left field... - Rocker brand & ratio? - Pushrod length, diameter & wall thickness? - Did you find the spring specs and any info on how they were installed?
Speaking strictly as an amateur bystander, I'm wondering if the opening & closing flanks are showing the result of insufficient valve train control, or a lubrication issue.
