Skid marks for sure. If you have straight enough pushrods angles you could try a rev kit? I considered trying one but i did not have room due to the prod angles. You also have to use a compatible lifer and we used .180 offset isky ez roll max roller lifter which are not.
Id be interested to see the difference when you measure the roller area vs the virgin lobe.
