I usually use MSD race ignition boxes on most of my Hi Pi street and strip cars but I'm hoping someone on here can recommend a good stock type 4 and 5 pin ECU for a stock type Mopar ignition system.
I've heard that some of the stock after market units are better than the Mopar OEM units with higher unrestricted RPM limit and I've heard the opposite also
I have several after market ECU, one from Accel is intermittent on wanting to start good so I replaced it with a stock Mopar black OEM unit and it starts right up but I've seen and heard that the stock ECU RPM are govern to run no higher than 6200 RPM, true or not?
I'm getting ready to license a 1966 Dodge Coronet 2 door Coronet Deluxe 2 door sedan that I put a 440 and NP833 O.D. tranny in it so I don't want the ECU restricting the performance on this car
Any recommendation on which brand and part # to use will be greatly appreciated
