My only tip to you about the PowerMaster Alternator is this. If you think the belt is tight make it tighter, they don't charge well with a loose belt. I had a "not charging" issue with mine, I tightened the belt and it helped. I think it could stand to be tighter. PowerMaster assured me that you can't get it too tight and it won't kill the bearings.
