I did put the PM alternator on. Im still not happy with it at idle. its around 12.8-13 volts at idle without anything turned on. with the lights on it idles around 12.4. if I give it gas it goes up fine. just not enough at idle. I started it with no ground on the field wire and it didn't charge at all. I put a 10 gauge wire on it and it started charging. do you know what the part number is on your alternator. My old 68 Charger had a painless harness in it I switched the alternator on it to a mid 90's truck 135 amp piece because of the huge fuel pump on it to feed the Procharger.
Sorry, do not know the part number. It's been on the car over 10 years, maybe 15.
Jack
