[quote=fourgearsavoy]Starting with a clean sheet of paper I would go with a 9" with NO FORD PARTS at all. Get a strong nodular center section from Strange and a Daytona pinion support and you will be fine with 35 spline axles and 4 pinion clutch style differential unit.
This is what the guys running in the 3's run. Next time at a big meet, look and see if I made that up. Actually, you won't see a Dana in those pits, anywhere.
I went that way a long time ago and I am still glad I did. Well, something else to ponder.
