Basically all ECU controlled units should be avoided as you would need a computer and several sensors to control the pump. Signal to the pumps is most likely a PWM (pulse width modulated) signal.
IMO the easiest solution for invisible A/C would be a low mount compressor on the passenger side and an electric fuel pump.
