No takers huh?
I guess I’ll get a set of rancho 9000 rear shocks and start at 8. The fronts I’ll leave the cheapies in- they’ll only get better as they wear out. I also ordered the M&H 275/50r17 DOT drag radials today. More sidewall and a bias ply like a 10.5x28 drag slick would probably help absorb the hit a little at the track but these are the best compromise money wise with the staggered wheels (16f 17r) I got off craigslist. I must have filled and emptied a summit cart a hundred times- I can fit up to a 13” tire in my tubs but would need a 6.5” offset to fit it on a 10.5 or 11” wheel. Even if I went 15” or steel wheels it was like $1500-2k.
Wish me luck and if I somebody wants to chime in again about the bags or whatever I’m interested in opinions or experience.
