Figured I'd bring this thread back to life. I just ordered the module bracket from designed2drive. Now researching modules and coils. I'm not extremely concerned with it looking original or even period correct. I made a plate that bolts on my firewall years ago using existing holes and my electronic ignition is mounted there. I'll probably make a new plate for the voltage regulator and new e-coil. I would also prefer to use the connectors designed for each whenever possible vs crimp on spades.
See several guys using the Ford coil, but not a lot of info on mounting. Found the Holley Sniper coil. A little more $, but looks nice, has a nice bracket and I hope to add Holley Sniper EFI whenever I have the money and can decide on an acceptable fuel delivery.
Found a Delco 4-pin module on Amazon.
I also see several recommendations of a Bosch relay.. I have the H&R(?) electronic ignition conversion harness. I hate to tear it up, but will probably pull out what I don't need and make a new stand alone harness.
