Oh! And reluctor points must be checked. THEY ARE NOT at same height! Once installed check the gap with every reluctor point and will notice some of them could be higher than others. The indexing of the rotation pin also gets the reluctor off centered a bit. File each one of them to the same height with pickup coil end.
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
