Only one I was concerned about was the drivers side on my 383/432 Stroker
Did it at work with a drill press
Two summers now
Cheap Anchor motor mounts from OReillys
Zero Zero Zero Vibration
Thanks for the pics. This might be the way to go. I see you assembled them, then drilled thru the mount and the bracket. Probably the easiest and cheapest.
