I've heard the Poly mounts and the so called "Bolt Thru" mounts cause a lot of vibration for a street driven restoration.
As I mentioned above I have the Poly Locs from Schumacher and I would venture to say no more vibration than factory rubber mounts....no fitment issues either, bolted on and fit like factory pcs....
