Although I do not have the intake caused leakage,,,leaks are on bottom side of covers,,,the spacer idea is intriguing as would raise cover up higher so lessen tendency for pooled oil to leak.
However it seem you would need 2 gasket sets,,,and would the spacer seal against head any better than valve cover currently does.
I do like the appearance of the Mopar Performance covers,,,,looks a bit more Mopar stock than some of the other perhaps better machined covers.
I currently have slathered permetex black about as I suggested in previous post,,,now setting a couple of days, time to take it out for a drive.
I also am planning to call Edelbrock to find what they have to say on this.
Rear main and valve cover leaks go with the game I guess,,,finally got the rear main taking care of,,,knock on wood.
Thank you all for your suggestions.
