Re: PB, 68 Charger
[Re: fast68plymouth]
#2647900
04/22/19 05:37 PM
04/22/19 05:37 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
So what do you get for flow now with the ball valve adjusted to maintain 6psi?
In any case, what you’ve done should show up on the time slip..... and you should find the car pulls in high gear better than it ever did.
Hopefully the weather will be nice the next time the track nearer to you has some racing. @ 6 psi it is @ 60 GPH, it is still borderline, but that is also @ 12 volts, 13.5 running volts should help some.
1968 Charger COLD A/C Hilborn EFI 512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim 2020 T/A 392 Stock 11.79 @ 114.5
Entire Thread
PB, 68 Charger
CSK
04/20/19 07:18 PM
Re: PB, 68 Charger
CSK
04/20/19 09:40 PM
Re: PB, 68 Charger
tex013
04/20/19 10:06 PM
Re: PB, 68 Charger
pittsburghracer
04/20/19 10:33 PM
Re: PB, 68 Charger
CSK
04/20/19 10:46 PM
Re: PB, 68 Charger
pittsburghracer
04/20/19 10:56 PM
Re: PB, 68 Charger
383man
04/21/19 05:12 AM
Re: PB, 68 Charger
CSK
04/21/19 05:30 AM
Re: PB, 68 Charger
383man
04/21/19 05:52 AM
Re: PB, 68 Charger
CSK
04/21/19 06:10 AM
Re: PB, 68 Charger
OhioMopar
04/21/19 04:28 PM
Re: PB, 68 Charger
fast68plymouth
04/21/19 06:33 PM
Re: PB, 68 Charger
CSK
04/21/19 08:09 PM
Re: PB, 68 Charger
fast68plymouth
04/21/19 10:22 PM
Re: PB, 68 Charger
Cab_Burge
04/21/19 10:49 PM
Re: PB, 68 Charger
CSK
04/21/19 11:25 PM
Re: PB, 68 Charger
CSK
04/22/19 02:53 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 03:19 PM
Re: PB, 68 Charger
CSK
04/22/19 04:41 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 04:46 PM
Re: PB, 68 Charger
CSK
04/22/19 04:57 PM
Re: PB, 68 Charger
CSK
04/22/19 04:58 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 05:17 PM
Re: PB, 68 Charger
CSK
04/22/19 05:23 PM
Re: PB, 68 Charger
CSK
04/22/19 05:24 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 05:28 PM
Re: PB, 68 Charger
CSK
04/22/19 05:33 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 07:09 PM
Re: PB, 68 Charger
CSK
04/22/19 08:56 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 09:25 PM
Re: PB, 68 Charger
CSK
04/22/19 09:37 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 10:16 PM
Re: PB, 68 Charger
CSK
04/22/19 10:23 PM
Re: PB, 68 Charger
an8sec70cuda
04/23/19 12:37 PM
Re: PB, 68 Charger
ZIPPY
04/22/19 03:22 PM
Re: PB, 68 Charger
CSK
04/22/19 04:33 PM
