Re: PB, 68 Charger
[Re: OhioMopar]
#2647570
04/21/19 02:33 PM
04/21/19 02:33 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I forgot that thing was EFI.
I would think it would be even more important to insure the fuel pressure is constant with that set up.
What system are you running that operates at only 6psi(or did you mean 60psi)?
Edit: looking at the specs for the Walbro 255 pump, I’d say you’re at the point where it may just not be enough pump. It’s rated for 630hp........ going by this:
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
Entire Thread
PB, 68 Charger
CSK
04/20/19 07:18 PM
Re: PB, 68 Charger
CSK
04/20/19 09:40 PM
Re: PB, 68 Charger
tex013
04/20/19 10:06 PM
Re: PB, 68 Charger
pittsburghracer
04/20/19 10:33 PM
Re: PB, 68 Charger
CSK
04/20/19 10:46 PM
Re: PB, 68 Charger
pittsburghracer
04/20/19 10:56 PM
Re: PB, 68 Charger
383man
04/21/19 05:12 AM
Re: PB, 68 Charger
CSK
04/21/19 05:30 AM
Re: PB, 68 Charger
383man
04/21/19 05:52 AM
Re: PB, 68 Charger
CSK
04/21/19 06:10 AM
Re: PB, 68 Charger
OhioMopar
04/21/19 04:28 PM
Re: PB, 68 Charger
fast68plymouth
04/21/19 06:33 PM
Re: PB, 68 Charger
CSK
04/21/19 08:09 PM
Re: PB, 68 Charger
fast68plymouth
04/21/19 10:22 PM
Re: PB, 68 Charger
Cab_Burge
04/21/19 10:49 PM
Re: PB, 68 Charger
CSK
04/21/19 11:25 PM
Re: PB, 68 Charger
CSK
04/22/19 02:53 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 03:19 PM
Re: PB, 68 Charger
CSK
04/22/19 04:41 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 04:46 PM
Re: PB, 68 Charger
CSK
04/22/19 04:57 PM
Re: PB, 68 Charger
CSK
04/22/19 04:58 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 05:17 PM
Re: PB, 68 Charger
CSK
04/22/19 05:23 PM
Re: PB, 68 Charger
CSK
04/22/19 05:24 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 05:28 PM
Re: PB, 68 Charger
CSK
04/22/19 05:33 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 07:09 PM
Re: PB, 68 Charger
CSK
04/22/19 08:56 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 09:25 PM
Re: PB, 68 Charger
CSK
04/22/19 09:37 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 10:16 PM
Re: PB, 68 Charger
CSK
04/22/19 10:23 PM
Re: PB, 68 Charger
an8sec70cuda
04/23/19 12:37 PM
Re: PB, 68 Charger
ZIPPY
04/22/19 03:22 PM
Re: PB, 68 Charger
CSK
04/22/19 04:33 PM
