Re: PB, 68 Charger
[Re: CSK]
#2647898
04/22/19 05:25 PM
04/22/19 05:25 PM
Posts: 14,514 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
So what do you get for flow now with the ball valve adjusted to maintain 6psi?
In any case, what you’ve done should show up on the time slip..... and you should find the car pulls in high gear better than it ever did.
Hopefully the weather will be nice the next time the track nearer to you has some racing.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
Entire Thread
PB, 68 Charger
CSK
04/20/19 07:18 PM
Re: PB, 68 Charger
CSK
04/20/19 09:40 PM
Re: PB, 68 Charger
tex013
04/20/19 10:06 PM
Re: PB, 68 Charger
pittsburghracer
04/20/19 10:33 PM
Re: PB, 68 Charger
CSK
04/20/19 10:46 PM
Re: PB, 68 Charger
pittsburghracer
04/20/19 10:56 PM
Re: PB, 68 Charger
383man
04/21/19 05:12 AM
Re: PB, 68 Charger
CSK
04/21/19 05:30 AM
Re: PB, 68 Charger
383man
04/21/19 05:52 AM
Re: PB, 68 Charger
CSK
04/21/19 06:10 AM
Re: PB, 68 Charger
OhioMopar
04/21/19 04:28 PM
Re: PB, 68 Charger
fast68plymouth
04/21/19 06:33 PM
Re: PB, 68 Charger
CSK
04/21/19 08:09 PM
Re: PB, 68 Charger
fast68plymouth
04/21/19 10:22 PM
Re: PB, 68 Charger
Cab_Burge
04/21/19 10:49 PM
Re: PB, 68 Charger
CSK
04/21/19 11:25 PM
Re: PB, 68 Charger
CSK
04/22/19 02:53 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 03:19 PM
Re: PB, 68 Charger
CSK
04/22/19 04:41 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 04:46 PM
Re: PB, 68 Charger
CSK
04/22/19 04:57 PM
Re: PB, 68 Charger
CSK
04/22/19 04:58 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 05:17 PM
Re: PB, 68 Charger
CSK
04/22/19 05:23 PM
Re: PB, 68 Charger
CSK
04/22/19 05:24 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 05:28 PM
Re: PB, 68 Charger
CSK
04/22/19 05:33 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 07:09 PM
Re: PB, 68 Charger
CSK
04/22/19 08:56 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 09:25 PM
Re: PB, 68 Charger
CSK
04/22/19 09:37 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 10:16 PM
Re: PB, 68 Charger
CSK
04/22/19 10:23 PM
Re: PB, 68 Charger
an8sec70cuda
04/23/19 12:37 PM
Re: PB, 68 Charger
ZIPPY
04/22/19 03:22 PM
Re: PB, 68 Charger
CSK
04/22/19 04:33 PM
