Re: PB, 68 Charger
[Re: CSK]
#2647829
04/22/19 01:17 PM
04/22/19 01:17 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I wonder if your pick up screen/filter is plugged.
Your findings are quite a bit lower than the spec........ although I’m a big believer in “it is what it is”.
Based on what your current pump tested at....... you need one that pumps a bit over twice as much(as that particular one).
Your 72gph free flow works out to 272lph.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
Entire Thread
PB, 68 Charger
CSK
04/20/19 07:18 PM
Re: PB, 68 Charger
CSK
04/20/19 09:40 PM
Re: PB, 68 Charger
tex013
04/20/19 10:06 PM
Re: PB, 68 Charger
pittsburghracer
04/20/19 10:33 PM
Re: PB, 68 Charger
CSK
04/20/19 10:46 PM
Re: PB, 68 Charger
pittsburghracer
04/20/19 10:56 PM
Re: PB, 68 Charger
383man
04/21/19 05:12 AM
Re: PB, 68 Charger
CSK
04/21/19 05:30 AM
Re: PB, 68 Charger
383man
04/21/19 05:52 AM
Re: PB, 68 Charger
CSK
04/21/19 06:10 AM
Re: PB, 68 Charger
OhioMopar
04/21/19 04:28 PM
Re: PB, 68 Charger
fast68plymouth
04/21/19 06:33 PM
Re: PB, 68 Charger
CSK
04/21/19 08:09 PM
Re: PB, 68 Charger
fast68plymouth
04/21/19 10:22 PM
Re: PB, 68 Charger
Cab_Burge
04/21/19 10:49 PM
Re: PB, 68 Charger
CSK
04/21/19 11:25 PM
Re: PB, 68 Charger
CSK
04/22/19 02:53 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 03:19 PM
Re: PB, 68 Charger
CSK
04/22/19 04:41 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 04:46 PM
Re: PB, 68 Charger
CSK
04/22/19 04:57 PM
Re: PB, 68 Charger
CSK
04/22/19 04:58 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 05:17 PM
Re: PB, 68 Charger
CSK
04/22/19 05:23 PM
Re: PB, 68 Charger
CSK
04/22/19 05:24 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 05:28 PM
Re: PB, 68 Charger
CSK
04/22/19 05:33 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 07:09 PM
Re: PB, 68 Charger
CSK
04/22/19 08:56 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 09:25 PM
Re: PB, 68 Charger
CSK
04/22/19 09:37 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 10:16 PM
Re: PB, 68 Charger
CSK
04/22/19 10:23 PM
Re: PB, 68 Charger
an8sec70cuda
04/23/19 12:37 PM
Re: PB, 68 Charger
ZIPPY
04/22/19 03:22 PM
Re: PB, 68 Charger
CSK
04/22/19 04:33 PM
