Re: PB, 68 Charger
[Re: CSK]
#2647788
04/22/19 11:19 AM
04/22/19 11:19 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If you did the test right....... then just under 22gph is what I get for 1qt in 41 seconds.
I assume you tapped into the system from the line that feeds the carb, installed a valve on the end of the line, turn on the pump and close down the valve to achieve 6psi system pressure. Then time the flow.
I would try it at 5, 4, 3 psi as well, just to see how low the system pressure would have to be to flow the fuel you need (50-55gph).
My experience has been that when flowing the entire system, while maintaining the required system pressure....... you need something like a 140gph pump....... for your power level(600-650hp).
I have seen many systems not pass this test when fuel pumps that are marginally suitable are used.
The question now is, is it the pump...... or a restriction in the line/system?
Did you see what the free flow was?
I know of one instance where the free low was more than adequate, but when tested at 6si, there was barely a dribble coming through(about 6mins to fill a gallon can).
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
Entire Thread
PB, 68 Charger
CSK
04/20/19 07:18 PM
Re: PB, 68 Charger
CSK
04/20/19 09:40 PM
Re: PB, 68 Charger
tex013
04/20/19 10:06 PM
Re: PB, 68 Charger
pittsburghracer
04/20/19 10:33 PM
Re: PB, 68 Charger
CSK
04/20/19 10:46 PM
Re: PB, 68 Charger
pittsburghracer
04/20/19 10:56 PM
Re: PB, 68 Charger
383man
04/21/19 05:12 AM
Re: PB, 68 Charger
CSK
04/21/19 05:30 AM
Re: PB, 68 Charger
383man
04/21/19 05:52 AM
Re: PB, 68 Charger
CSK
04/21/19 06:10 AM
Re: PB, 68 Charger
OhioMopar
04/21/19 04:28 PM
Re: PB, 68 Charger
fast68plymouth
04/21/19 06:33 PM
Re: PB, 68 Charger
CSK
04/21/19 08:09 PM
Re: PB, 68 Charger
fast68plymouth
04/21/19 10:22 PM
Re: PB, 68 Charger
Cab_Burge
04/21/19 10:49 PM
Re: PB, 68 Charger
CSK
04/21/19 11:25 PM
Re: PB, 68 Charger
CSK
04/22/19 02:53 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 03:19 PM
Re: PB, 68 Charger
CSK
04/22/19 04:41 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 04:46 PM
Re: PB, 68 Charger
CSK
04/22/19 04:57 PM
Re: PB, 68 Charger
CSK
04/22/19 04:58 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 05:17 PM
Re: PB, 68 Charger
CSK
04/22/19 05:23 PM
Re: PB, 68 Charger
CSK
04/22/19 05:24 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 05:28 PM
Re: PB, 68 Charger
CSK
04/22/19 05:33 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 07:09 PM
Re: PB, 68 Charger
CSK
04/22/19 08:56 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 09:25 PM
Re: PB, 68 Charger
CSK
04/22/19 09:37 PM
Re: PB, 68 Charger
fast68plymouth
04/22/19 10:16 PM
Re: PB, 68 Charger
CSK
04/22/19 10:23 PM
Re: PB, 68 Charger
an8sec70cuda
04/23/19 12:37 PM
Re: PB, 68 Charger
ZIPPY
04/22/19 03:22 PM
Re: PB, 68 Charger
CSK
04/22/19 04:33 PM
