Big clearances with light oil. You can't be squeamish about oil pressure if you go down that path. Especially at hot idle. You may as well take that 30# transducer for the light and throw it in the trash. Put a 15# in it and put up with the light flickering at you coming back the return road.
If the results don't match the theory, change the theory.
