Well that's were we slightly differ. 22 amps at idle will be enough for running the car with lights on. If it needs to do more than that, like also run wipers and heater fan while idling, then more is good. 45 amps at idle can be bad with a battery that's been drained and had a jump start. So if not needed, I don't push it.
