If the crank is cut with the 2.200 BBC journals...is there a better selection of main bearings? 440source kits come with bearings.
So I will look at different Cam options too. The MP 590 is as old as the TRW 2293's that came outta my 383...
Dwayne...i hear you about wanting more power in the future...but I can build for that then. Winters are long here as you know:) I will have to look into your services.
