I have a 1973 400 block (630) that I want to build to 550-600hp for the dragstrip only. So far I was thinking after all my research, is to stroke the engine with Trickflow 240 heads. I read AndyF's Max-Performance book and was thinking 451 or 470...or maybe go right for the 512???
Can you more experienced racers give some suggestions of a build that might work for me? It looks like my budget is about $10K
Below is an idea for a build...
- 440source stroker kit with 2.200 BBC journals
- compression at 11-1 or 12-1 (high octane pump gas or 110 race gas)
- 590 mopar performance flat tappet cam
- Trickflow 240 heads
- single plane intake with holley carb
