Quote:Quote:haha why do you think i should use longer axles ?what is the purpose of axle adjustment and spacer? will the axle walk out or in?thanks again guys the purpose is to keep the bearing in the cone and basicly preloads , though there is side to side movement, the bearing .It's a demo car , weld the spiders or use greens , you are running on dirt , no big deal and ""if the bearing breaks so what ? ""
