other than the standard bracing (kmember, inner fender braces, lower rad braces, sub frame braces and torque boxes) I stitch welded the entire body, and I added these triangular braces from the crossmember brace to the fram rails from left over metal from the subframe braces - I figure with the higher loads from the beefier torsion bars it couldn't hurt
