Without power to the small lug the solenoid won't close and complete the alternator circuit.
With the switch ON, power from the ON side of the switch supplies power to energize the solenoid and complete the alternator circuit; with the switch OFF the solenoid is de-energized and the alternator output is removed from the system.
This prevents the alternator from supplying power to the car and defeating the purpose of the kill switch.
