Been a long time since I've been here, just been busy as usual. Quick question. Have a trunk mounted battery. Need to install a kill switch for it. I currently have one with only the two hot leads on it, not the type that has the two hot leads and the jumpers, I guess they are called. Can I use the one I have and if so, a diagram how to wire it in? Thanks in advance,
