Russ, by the “new” hemi grind...... you mean the 280/.474-110?
I never tried one of those. Seems like there was some deal where it came without lifters, and by the time you bought the lifters the cost ended up being quite a bit more than a 484 or 509 cam & lifter kit.
If I stumbled across a NIB one now I might pick it up if the price was right.
Fundamentally I like solids so much better it’s unlikely I’d ever use it in one of my own motors though.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
