Todd @ Marsh Performance is a NC guy and/or David Klutz (crabman 173) would get you there with no drama and the desired result.
I know several others in NC who I will let machine stuff for me depending on what part of the state you are in may or may not be useful.
Marsh performance is almost two hours away (which I wouldnt have much of a problem with if it was the closest one), but David Kluttz works for HP engines correct? I remember reading in article HP engines is mentioned in (the AMSOL engine challenge) and it was David Kluttz working with HP. So does he work there or was he just helping them out?
