My one final question would be, with this setup and the voodoo cam, should i go with 3.55 or 3.73 gears? Again its a daily driver that I’d still like to rip off the line every once in awhile.
I have a 440 Cuda hemi 4 speed, 3.55 car. DEFINATELY DO NOT go with 3.23s! You have overdrive, my first choice would be 3.73's if you have them, but 3.55s will work fine.
I THINK I am running the Lunati Voodoo you are talking about (they changed part numbers several years ago and I lost track).
My cam is the .493 / .513 lift. 268/272 duration(I think).
Powerband comes on at 1900 and pulls hard. Anything less than 1900 will lug under throttle. I have not found the top end, but I've only looked for it up to about 6200.
I would LOVE to have an overdrive, but it's not worth the expense and work to go for it...for me.
