What all parts are required to replace a single reservoir master cylinder to a dual on a 1964 fury with the HD brakes. Also, what master cylinder is best to use to do the swap?
Thanks!
Dan,bet you're sorry you ask !!
Bill, I do feel a little guilty starting something then leaving the room, just hope to see the end of all ends for the answer to the outcome. Some great info here!
No you are not at any fault as I want to appoligize to you for us hijacking your post. Sorry as I don't believe that's what any of us meant to do. Ron
No apology needed Ron, some good information was gathered here!
