Id put the jets back to last year. then check Cam degree!
Checking that the cam is installed properly is easy and can be done in the car. I had one where everything was installed correctly but was way off from where it should have been.
'63 Dodge 330 11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs. 10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
