Gus I may take you up on that .. here is a run done on the car
It’s now a 493 -1 ported heads from modern Ported intake 1050 AED carb 95 primes and 96 second shooters I could tell you 11-1.1 comp Crank trigger Msd 6 al Small roller 316-321 283 and 288 at 50 and .660- 663 4500-7200 Timing is set at 34 Checked wiring and all other small things. This thing should be running 9.5 or better . Things a beast In the Pitts and road but track not so much. I’m at a Lost.
