A few weeks back I started a thread regarding my RB based stroker build asking for "your 2 cents". I am finalizing my purchase list and would like some input on cam choice. I spent some time on the phone with the guys at Hughes Engines and they seemed pretty excited about this specific grind noted below.
I attached a link to the original thread for anyone who wants to get caught up.
https://board.moparts.org/ubbthreads/ubbt...tml#Post2522684The build as it sits on paper:
RB based 440 Source 505/512
4.25 stroke
4.350 bore
-17cc dished pistons
440 source main caps
ARP studs
Trick Flow 240 Heads
Trick Flow Single plane intake
Harland Sharp 1.5 Rockers
Hughes Solid Roller Cam:
260/264 .675/.675 lift @110* Installed ADV 4*
The Magic Bench Dyno says 666HP at 5700rpm and 650ftlbs at 4200rpm
Does this seem legit? Thoughts opinions?
