Originally Posted By Clanton
Originally Posted By mopar dave
Ok. The race gas did richin it up a bit. Ill try the .055 first. Ran good with those and go from there. Thanks Dom.
You want to stick with 1 fuel grade till you learn the spread from each fuel on jetting.I did a couple 60' launches in my drive and read my plugs till I move on to the next step of jetting.[add pv]I have #7 plugs in.
What fuel are you using and what plug is that?
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
