I think plug reading with street driving and pump gas is going to be a waste of time. If it feels happy and good roll with that. You are going to have poor distribution at low load and overlap and reversion further messes things up. Your intake isn't designed for putzing around town, it is designed with a RPM range in mind, when it is running in that range distribution will be way better.
Yup.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
