1968 Dodge Charger,4050lb with me Street car, COLD AC, 512 low deck, 440 source stroker kit
9.7 compression,Morel high rpm roller lifters, Hughes hydro roller cam 255,258@.050,
.608/.613 lift with 1.6 T&D rockers with B3 geometry correction, Indy 400-2 intake
that I ported to max wedge,1050AN 4150 pieced together carb,
440 source Super stealth heads max wedge size that I ported flow 330 @ .700, with Farrea valves,
Comp Beehive springs, 1 7/8 headers, full 3" magnaflow exhaust & tail pipes.
A518 overdrive trans,4000stall lock up converter, alum driveshaft,
3.54 Strange Dana 60, Caltrac bars & split mono springs with sliders.
325-50-15 MT drag radials street. drove 80 mph, 80 mile round trip to the track, dropped the air pressure in the rear tires, turned of the AC & made a easy , short shifted pass, next pass went up against the converter 2500 & it blew the tires off, got to hot outside for me, drove home in the ac. smile
That sounds like a fun ride! Who built the 518 and what did it take to make it work with the high HP Big Block? How much work was required to make it fit the B body trans tunnel?
