The OP didn't choose the best conversion kit for sure and that is the main problem. And Summit's parts aside, there are other Mopar disk/disk master cylinders that will fit and work on his power brake booster. They may not be listed for a Barracuda, but given he's using GM style rear calipers, going with a non Barracuda Mopar master cylinder seems trivial.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
