A quick search turned up disk/disk masters for '73 Barracuda at Summit, and I'm sure a quick trip to Napa or AutoZone would turn up more. My point is.. you can use a disk/drum in this situation but when an engineered disk/disk version is available why jury rig the system. Makes no sense to me but then apparently, I'm no expert since you guys seem to think barbed wire and bubble gum is a better idea.
that would be a hell of a trick since a 73 Barracuda never had 4 wheel discs from the factory. Care to link to it, because whatever you think it is, it's not stock and it's will be a jury rig. Surprised you don't seem to have heartburn with the OP's setup since it is all a jury rig.
