then suggest one that will fit his booster rather than pontificate.
Other than the reservoir capacity and rpv there is no difference and if you can't be bothered to check fluids at each oil change then maybe you should be using Uber.
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
