In one of the pics you have a red arrow pointing to a ragged piece, this appears to be the plastic spacer between the Belleville and the wavy snap ring, plastic was used from the early seventies on.
The pic shows the different style spacers, at right is black plastic, next is white plastric, next is continuous loop steel (the best) and far left is split steel.
