Ray
I know they dont look like stock, and cause some headaches as far as pulley alignment, alt setups. But once you go that route, and see what a easy setup it is, and working on it, you will be asking your self why you hadnt done it before..
And I make them my self. I just used some 1/4 steel and swiss cheesed them to lightning them, and give them more of a custom look. Just used a couple water pump gaskets as temp-lets and went to town. I fired up the Torch and cut the holes, they look like they were cut with a hole saw for the most.
I like doing these kind of parts my self, and it save's me a C-note too
Not a great pic, and have since moved the fuel isolator but you get the idea.
