Thanks both
Robert,what i did yesterday was to connect the wires of my multimeter to the dist.connector and turn the shaft by hand(The multimeter on the beep/continuity mode) and it made that a cricket insect sound.
However, that signal does not arrive to the orange box.What i mean is that if i connect the dist connector to the car wiring and the multimeter wires to the orange box connector pins,the cricket does not sound.
I don,t understand why, because there is continuity between the orange box connector pins and the connector that goes to the distributor.
I did a video,is horrible because i was holding my celular so i only had one free hand,but more or less you can see what i checked out.
https://youtu.be/5RKR3-KUo8w
