roll out of the water to the edge of the water,some like to spin the tires in the water box,then go to the edge ,all that does is put water in the wheel well,which can fall on tire going down track,start your burnout in 2nd gear,never in 1st,then go to 3rd,count to 5 then roll out,,big smokey burn outs isnt needed,stop clean out the carb then go to the line
