well Dave ,
looks good . ran mine again plus 30 odd miles . looks like I may be plain unlucky . still some oil though not as much as before . will just have to put up with it for the short term . I think I will order some Superperformance rear seals , plus a few other gaskets . Then pop trans to double check it is not the oil pan now that I am no longer running the windage tray .
argh crapola
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
