Ok, I am back again. Problem is still with us. This is is what is going on. Start the car and it runs perfect for the first 2 or 3 minutes then it starts to skip or miss. I can see this with the timing light hooked up. When the car misses the light will go out momentarily. Could this problem be the ballast resistor? When driving the car is just loses power when you try to go above say 20 mph. Any help is appreciated.
